Thread: AquaLink® Z4
    Mar 2015
    Lebanon, PA
    AquaLink® Z4
    Anyone have any experience with the AquaLink® Z4.
    Thinking about installing one to control my pump, heater, light and stenner pump
    Located in Lebanon,Pennsylvania.. 25,000 Gallon IG Plaster Pool Installed Fall of 2011...
    Stenner 3GPD pump
    Jandy DEV60 60SqFt DE Filter (Using Puri fiber.)..,1.5Hp Jandy Pump PMPH1.5
    Aqucal SQ 166R Heater...Polaris 9400 Robot/Cleaner
    TF-100 Test Kit
    Mod Squad Patrick_B's Avatar
    Jun 2011
    Re: AquaLink® Z4
    I'm not sure, but I'm giving you a bump to help you get some replies.
    Essential Links:
    TF-100 Test Kit, ABC's Of Pool Chemistry, Test Kits, SLAM Your Pool
    28K Gal IG FreeForm, CLI Quartz, Flagstone, 36"SF, Pentair VS Pump, EasyTouch W/Remote, Rheem 400KBTU Htr
    DFW, TX
    Re: AquaLink® Z4
    Have you tried a search on aqualink in the upper right corner? I just looked and there are a lot of threads discussing it. Maybe that will help to answer some of your questions.
    Re: AquaLink® Z4
    Other models of the Aqualink are common, and there is lots of experience with them. But the Z4 is brand new and you are the first one who has even mentioned it, let alone seen one. A number of us would be happy to comment on Aqualink generally, but we just don't know anything about the Z4 in particular.
