- Aug 31, 2014
- 5
- Plaster
- Pentair Intellichlor IC-40
It's been a long time but I am back and needs some assistance. I have a dead Intermatic (PE653ERC) controller and my Pentair pump started acting up and the display froze up and would not respond to any button press even after disconnecting the control cable and powering off for an hour at the beaker.
Took apart the pump control screen. Dries up the water behind the buttons. No noticable corrosion on the board. I put it back together and reinstalled that night. No luck with it powering up, screen lit up but wasn't displaying anything. 24 hours later turned the breaker back on and I am able to manually control the pump but still just a blank lit up display.
Good news is the pump works but I have no automation. Looking for suggestions on next steps. I would like to replace the automation system but I am at a loss for what to go with. I am all Pentair.
Next item is the pump display. I rarely use it. Should I replace the control module?
I appreciate all suggestions.
