Results 1 to 11 of 11
Thread: 3 way valve install, electric operation?
    Dec 2014
    San Diego/CA
    5
    Does the input on the 3 way valve matter or can it be any port depending on where the electric valve mechanism is positioned or?
    38,475
    Re: 3 way valve install, electric operation?
    Welcome to TFP!!!
    Ideally the middle port on the valve is the "common" pipe where water is always flowing. The actuators usually come setup for a 180 degree rotation which would have the common pipe in the middle.
    BUT ...
    The 3-way valve can be used in any orientation and the cams in the actuators can be adjusted to give you any amount of rotation you need for any valve orientation. The manual explains how to adjust the cams.
    Dec 2014
    San Diego/CA
    5
    yes, I will need the 90 degree for ease of plumbing... attached is what Im looking to do for the solar. Have a controller and have to set it to open and close correctly, looks like I will have to plug it in and see what it does?
    38,475
    You will certainly have to adjust the cams to make them a 90 degree rotation. The manual for the actuator shows the orientation to mount the actuator to the valve and what the cam settings need to be.
    Note that the handle you drew in the picture would actually close the main intake pipe from the right (not what you want to do).
    Dec 2014
    San Diego/CA
    5
    just drew a handle, but did update the above picture to be correct (I believe).
    38,475
    Yup
    Dec 2014
    San Diego/CA
    5
    also what are the best check valves to use for this application?
    You want a flap style check valve, not a spring style valve. The Jandy Pro Series check valves are excellent.
    38,475
    I know Jandy and Pentair make them specifically for pools that are better than the PVC type. If you are interested in your flow rates, you could get one of the Flo-Vis from tftestkits.net http://tftestkits.net/FloVis-Flow-Me...plete-p74.html
    Dec 2014
    San Diego/CA
    5
    looks like the jandy have a rust problem
    looking at the Pentair 263042 Check Valve CPVC, thoughts on this one? They are saying need about 12" on both sides of the check valve also that will be tuff with it being next to the heater (heater is on the left out of picture) want it as far away as possible should I use a different style in my application * see pic above *?
    38,475
    The Jandy are rebuildable and the Pentair are basically the same design.
    I have never heard of the 12" requirement for a check valve. I certainly did not adhere to that.
