I'm installing a Jandy NeverLube three way valve (part #4715). Here are the installation instructions.
1. The instructions say "The internal valve assembly must be removed prior to gluing valve body to pipe fittings. Make certain no glue enters valve body beyond ports." Is it really necessary to take apart the assembly? I guess the idea is to remove any chance of glue getting stuck to the rotating mechanism inside. But it seems to me I'm way more likely to mess stuff up by uninstalling the whole mechanism and putting it back together. Seems like I can just leave it as is and be careful with the glue, no?
2. The instructions say "Be sure the word “INLET” on valve cover is over the incoming flow port." If we're thinking of the valve as a T, the INLET is at the bottom of the T. Is there a reason the water needs to flow in from the bottom of the T, rather than from the left or right side? Not a huge deal, but it will make my install a little tougher if the water has to flow in from the bottom of the T.
