Results 1 to 7 of 7
Thread: Swimming with pump on
    Jul 2014
    Northern Minnesota
    51
    Just wondering if it is ok to swim when the pump is running? I have been but then started thinking about possibly electricity and water. The pump I am using is the pump which came with the intex pool. Any thoughts?
    Intex 15 ft x 42" Above Ground Pool bought from Amazon (3, 284 gallons)
    Standard pump and cartridge filter that came with the set up (1,000 gph)
    I live in Northern, MN
    Re: Swimming with pump on
    Some of the Intex pumps are not certified for use while people are in the pool. Other Intex pumps, and nearly every pump of any other brand is fine to be used while people are in the pool. Check your pump manual. They will explicitly state if it is a problem, might not say anything if it is fine.
    A side conversation about Intex pump instructions has been moved to here.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    I have two drop cords running to my pool...one for my filter and one for the SWG....i'm relying solely on the built in GFI in the cords of the units....i'm probably wrong in doing this, but we swim in it while its running.
    edit: in fact...after reading idiotic my own post is....we are no longer going to swim with the pumps on. ...now i need to find an electrician
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    wjr75's Avatar
    Jun 2013
    IL
    836
    All pool inspectors will make sure you have at least a GFI outlet installed and you should test it every once in a while. I had to replace a few outdoor ones this year that didn't test properly. Not sure about your actual Intex pump if it is safe or not.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Apr 2014
    FOUR cORNERS
    111
    well use ours, (sand filter) when the grand kids want to play under the fountain!! turn pump to recirculate, close skimmer, open valve on fountain, play. Note : we do have original suction port in operation.
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Jun 2014
    clinton
    25
    We'll let ours run unless it gets rowdy in the pool, i think people stiring the bottom up while the pump runs helps filter out some of the smaller debris. Unless there was a collapse i dont belive water is actually in contact with any metal durring circulation. How ever im not so sure how the intex pumps work.
    Mid Missouri
    227
    We swim with ours on. I removed the factory ground fault protection, my pump is plugged into a circuit protected by a ground fault breaker at the panel.
    A side conversation on GFI vs GFCI has been moved here. JasonLion
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
