Thread: Jandy relay problem
    Jan 2010
    Spring Texas
    47
    Jandy relay problem
    Pump will not turn off except at breaker. I have a new 3hp relay (new is pic 1) but it looks nothing like the old one (pic2-3-4). The connections are different and nothing looks comparable. Any suggestions?
    20000 gal in ground Pentair Screenlogic 2 ez-touch 4
    Teledyne heater Compupool 40k Salt generator
    Pentair VS pump Hayward 4025 Cartridge Filter
    12 person Spa The Pool Cleaner robot
    lot of bushes and trees close to the pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Jandy relay problem
    Maybe it's wired differently for NC/NO? I went through this with some new control relays recently. I've has one case where a brand new relay wouldn't open the circuit too. That said, I am not an Electrician and you should seek technical assistance from someone that is familiar with these. Sorry,I know that's the last thing you wanted to hear, but I'm just not qualified.
    Essential Links:
