- Nov 19, 2020
- 21
- Pentair Intellichlor IC-40
My PB’s plumber relocated 3HP Pentair VS pump and I later noticed that he just cut old 2’ pipe to the edge and left that inside check valve and then spigot new 2.5” pipe in n the check valve. Pump has 3” suction line before this check valve. It looks like pipe size is going from 3” suction line to check valve 2” ID then 2-2.5” check valve then 2.5” pump inlet to 2.5” outlet. Do you think it will cause pump to run hard due to kind constricted check valve or he should have ideally put a new 2.5-3” check valve? Any suggestions and recommendations..
