Results 1 to 18 of 18
Thread: Advice with solar panel and pump
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    We were wanting to add solar panels to our roof. The problem is it's the 2nd story it is 20ft up to bottom of eve and 25ft from pump. I think we will need 4-6 4x12 panels. Will our pump be able to handle it ?
    13k - Martinique 15x30 52"
    Sta-Rite crystal flo 22" sand filter & 1.5 spl rated
    Gorilla pad / waveless wall foam / foam cove
    Buried 2ft TF-100, TFPC
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Advice with solar panel and pump
    Can you post the pump model number?
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    Working on pic.. thx
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What size plumbing do you have? I am not certain, but I think you may have trouble priming the panels at that height with that pump.
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    I have 1.5 to and from
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    [attachment=0:325cdep1]20130810_141536.jpg[/attachment:325cdep1]Work in progress..
    38,272
    The 1.5 SPL means that the pump is really more like a 1HP pump. I too think it may struggle some, but am not certain.
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    I didn't know that. Thx I have a large backyard but didnt want that many panels on ground taken up so much room.
    38,272
    FYI, the true pump rating is based on the list HP and the service factor (SF). Manufacturers play games with the numbers for marketing.
    For example taking the Pentair Whisperflo line:
    WFDS-4 is called "full rated" with a HP = 1 and SF = 1.65 so the SFHP = 1.65
    WFDS-26 is called "up rated" with a HP = 1.5 and the SF = 1.1 so the SFHP = 1.65
    These 2 pumps are IDENTICAL besides the numbers on the sticker.
    Some above ground pumps have a SF < 1 and are designated with the SPL. It may even say on the sticker something like HP = 1.5 and SF = .66 making the SFHP = 1.0 or maybe the SF = .8 making the SFHP = 1.2 which would be the same as a non-SPL motor with a HP = 1 and a SF = 1.2
    On top of this, the wet-ends are designed differently, so all 1.5HP pumps may not perform the same. For example the Pentair Superflo is a smaller pump than the Whisperflo even though the HP may be the same.
    For AG pumps, one consideration is the head-loss. Most are NOT self-priming because they are below water level and are called "low-head" pumps because they are generally right next to the pool and there is not a large resistance to the flow ... so the pump does not have to work as hard. These "low-head" pumps may not have to ability to pump water up 20+ feet for a high solar system.
    What I am not sure of is what the "head rating" {I made this term up} is for your pump.
    Wow, sorry that got so long.
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    Thx, That wasn't too long at all when we are about to drop 1k on panels.. How can I find that out(head rating) I have been reading hydraulics section but some of this is kinda hard to understand. Which at work I run hydraulic motors and large blackmeer pumps. So I am not completely lost
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    Found it model 193262
    38,272
    Well, you can find the head curve here: http://www.pentairpool.com/pool-owner/p ... ps-432.htm which shows that is is slightly less powerful than my pump.
    It "should" work if you keep the VRV lower. Let me see if we can get Mark to take a look.
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    Ok that would be great help. I was just reading that. The power curve . And dont think it could get the flow started. I may need another plan mayb just buy another pump just for solar
    38,272
    Well, according to the curve, if should be able to pump the water up 50 feet of so, but that does not account for the losses in the filter, and the other plumbing and in the panels.
    My Superflo curve starts out around 65 feet a zero flow and it is I think just adequate to run my solar at good flow on a single story. But I have a lot more plumbing to the house than you do.
    You can certainly help by using 2" pipe and fittings for everything you add.
    BTW, I PM'd Mark, so hope he will help.
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    I started with 1 1/4 didnt like that at all so went wth 1 1/2 . I was considering 2" but my skimmer and return had 1 1/2 fittings
    mas985's Avatar
    Pleasanton, CA
    11,737
    The Dynamo should be big enough to handle the priming for solar. It is classified as a AG pump but it is self priming and has medium head. I would definitely try it out first before buying a new pump.
    Mark
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    Oh, Light bulb. I will go with 2" Now that I look it over with new ideas I can run female threaded pvc, the only restriction will be the skimmer to pump basket. Which I do not even use the skimmer that much except to go thru, I pull from bottom under ladder, when noone is swimming.
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    Thx so much.. I will run sum pipe up and see how it does..
