I have a Jandy JHP1.5 Stealth pump with a Century 1.5 hp (1.95 thp) motor manufactured in 2003. I need a replacement motor for the pump and I'm looking at variable speed motors. I have an 18,000 gal in-ground pool that receives infrequent use. I have seven 4' x 12' Heliocol solar panels on a second story roof supplied by 2" pipe (110' total length of pipe to end of last panel). Pump is 25' from the pool and has a 2" supply lines from both the skimmer and the floor. I'm looking at the Century V-Green motors. They come in 1.65 , 2.25 and 2.7 hp. Any recommendation on which would be the best replacement?
Thanks in advance for any advice!
