- Nov 12, 2017
- 11,872
- Plaster
- Pentair Intellichlor IC-40
I think they are 12.5' x 4'.You said you had 8 panels but what is the area of each? 5 GPM would imply 12x4 panels? What is the panel tilt and the direction they are pointed?
Panel tilt = This-much degrees.
Direction = Over-yonder.
Ha, ha, I don't know! The roof is what it is and the house sets how it sets!
But I'm hearing you. So many variables, but physics is physics and there are formulas to figure it all out. I just happened to approach it from the other end: can't change the angle or direction. Can't change the height above the pool. I maxed out available space of the roof. All I could really control was flow rate and runtime. Runtime is bracketed by SWG need and available sun. So really it just came down to flow rate. The $120 my Vis cost was cheaper than the time it would have taken me to learn any other way to get flow, so I went with the Vis. And I trusted Heliocol for the correct rate. I figured they'd know more about what their panels need than any other source.
So my pool gets as warm as it gets, which is some of the time warm enough! I've spent more time and effort learning from you and others here how to advise TFPers (none to well, as it turns out), than I ever spent learning what to do about my own system before I installed it. I'm convinced I've optimize my own system correctly, but it's clear that every install is unique, and needs its own unique optimizing MO.
