Results 1 to 8 of 8
Thread: pool filter
    pool filter
    I have a Hayward DE filter system. While I am vacuuming my pool the dirt is shooting out the return pipes right back into my pool. Why is this? Thanks.
    38,275
    Re: pool filter
    Welcome to TFP!!!
    Well, either you are set on Recirculate. Or you did not add enough DE after the last backwash. Or your backwash valve is allowing water to bypass the filter. Or there is something wrong in the filter (torn grid, broken manifold, etc).
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: pool filter
    Which DE filter model you have? grids or fingers? Do you have a backwash valve?
    i asks as i have a Hayward DE, fingers and NO valves. Very different than many IG pools.
    -- Guy --
    Re: pool filter
    I have a grid like filter, they are like panels. I do have a backwash valve, after I backwash and add DE it comes out into the pool also. I just spoke with another individual and they mentioned there may be a rip in one of the filter panels and that may cause it. Does that sound accurate to you?
    38,275
    Re: pool filter
    That was one of the posibilities I listed.
    Re: pool filter
    Great, thanks for the help.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: pool filter
    You can normally find a replacement grid to replace the blown out grid. They are pretty easy to change. Do a search before you take it apart to see if there are any hints for your model.. Some of them are fragile when you take the top spanner off.
    I don't have this style but IIRC some of them suggest only removing one grid at a time and replacing it before moving on to the next grid. They can be hard to rebuild if completely taken apart. Also, some of them have fragile areas.
    These are not to scare you off from doing it, but rather to let you know it can be done and help is available.
    -- Guy --
    Re: pool filter
    Thanks for the advice.
