Results 1 to 11 of 11
Thread: Planning to wire up the new motor this weekend
    Jan 2013
    Houston, TX
    1,079
    Gents,
    Planning to wire up the new motor this weekend. B2983 - Recommendations? 10, 12, 14? SHP is 2.20
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jan 2013
    Houston, TX
    1,079
    Re: Solid vs Stranded Wire
    Bump. Thinking you gurus missed this because it was early.
    38,248
    What size breaker are you using ... that determines the wire size ... assuming you do not have some ridiculously long run.
    The pump is only 10A, so you could use a 15A breaker with 14 AWG wire ... again if the run is not too long.
    Jan 2013
    Houston, TX
    1,079
    Re: Planning to wire up the new motor this weekend
    I'm replacing the section from the timer to the pump - about 10 feet all said. The breaker is a 20 amp.
    38,248
    With a 20A breaker you have to use 12AWG.
    Jan 2013
    Houston, TX
    1,079
    Thanks guys. 12g stranded it is. Wiring up tomorrow.
    Jan 2013
    Houston, TX
    1,079
    [attachment=2:14wsaorz]ImageUploadedByTapatalk1369492891.856379.jpg[/attachment:14wsaorz][attachment=1:14wsaorz]ImageUploadedByTapatalk1369492907.287901.jpg[/attachment:14wsaorz][attachment=0:14wsaorz]ImageUploadedByTapatalk1369492919.853208.jpg[/attachment:14wsaorz]
    So I figured out where the algae was hiding that was impacting my overnight drop test...
    More to come as we roll. Off to Home Depot for some electrical parts
    Jan 2013
    Houston, TX
    1,079
    Bleached scrubbed and drying in the sun..[attachment=0:1p9yve75]ImageUploadedByTapatalk1369493054.667379.jpg[/attachment:1p9yve75]
    Jan 2013
    Houston, TX
    1,079
    It's installed!
    There was a little confusion on the L2 post ... That is where your unswitched hot leg goes. I don't think that matches the side of the pump but it is what the engineering drawing on the century site has. Other than that and a nail in my tire from the HD run it has been uneventful.
    So this is the water flow on low (and I can't hear the pump at all)
    [attachment=2:3td4ms7o]ImageUploadedByTapatalk1369513515.590863.jpg[/attachment:3td4ms7o]
    And this is the water flow on high
    [attachment=1:3td4ms7o]ImageUploadedByTapatalk1369513559.021097.jpg[/attachment:3td4ms7o]
    On high there is no perceptible difference from the B855. I'm glad I went with the b2983 instead of the 84. High with the 84 just would have been too much.
    Not all the way cleaned up but you get the picture
    [attachment=0:3td4ms7o]ImageUploadedByTapatalk1369513687.157510.jpg[/attachment:3td4ms7o]
    Pressure on high is 22 low is 9
    Jan 2013
    Houston, TX
    1,079
    Correction on the flow on low[attachment=0:1722jg5x]ImageUploadedByTapatalk1369516322.218563.jpg[/attachment:1722jg5x]
    We like it! Sounds like a brook.
    38,248
