Thread: foam board?
    wolfy's Avatar
    May 2012
    Randleman, North Carolina
    33
    foam board?
    I have a 15x42 Intex frame pool. I am considering using Pactiv 1/4-in x 50-ft x 4-ft Extruded Polystyrene Insulated Sheathing underneath. I also will sandwich it between tarps. Does this sound ok?
    16x48 Intex Ultra frame pool with swg
    May 2013
    Littleton, NH
    22
    Re: foam board?
    That's a good idea if it will work. Probably cheaper than buying the 1/2" or 1" 4X8 sheets. I'd be curious to know what others think on this idea. I might do it as well.
    Intex 18' X 48" Hard Plumbed running the 1800gph pump that came with it. Using BBB method
    Aug 2011
    Virginia Beach
    295
    Re: foam board?
    I did it on mine! (but I used the pink stuff from Home Depot)
    I'd trim the edges too. Rain and splashout will not drain through it.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
