Thread: spa clean out.
    spa clean out.
    getting spa ready it was empty not used for a year, just bought it and had it delivered.
    How can I disinfect or clean it (plumbing) all out before use?
    Is there a standard practice.
    30,432
    Re: spa clean out.
    Chlorine at shock value will work. Probably several hours and then let it fall to normal.
    Re: spa clean out.
    I suppose it should be filled and rinsed out a few times there after?
    Oct 2012
    209
    Re: spa clean out.
    I guess that would depend on what comes out of the plumbing. If it's absolutely disgusting you might want to drain, re-fill, and re-shock again. Otherwise your filter should catch any dead stuff that gets pushed out of the plumbing and as long as it looks good, leave the water.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: spa clean out.
    I would follow the disinfection procedures referred to in this Pool School article that references this procedure. Also, there could be substantial biofilms that formed if the spa was not dried out when stored in which case you can use Spa System Flush. A simple shocking with chlorine is not enough to get rid of biofilms and spas that go unused with water left in the pipes can form significant biofilms.
    30,432
    Re: spa clean out.
    Well, I should have been diligent enough to seek out or remember that article. I would take chemgeek's advice over mine anytime!
