- Apr 12, 2016
- 645
- Fiberglass
- Pentair Intellichlor IC-40
So, I posted on this before but its been a while and I could not find the thread, anyhow....
I know there is mention of getting rid of iron in water to keep the tub clean and here is my method, easy, small expenditure, and always works!
I started out by noticing my sand filter in my pool would clean the iron out in a day turning the water from a pale green back to a nice blue, the cartridge filter in my hot tub would not do it so I used to fill my tub from my pool after filtering out the iron. So.....
I bought a small pool sand filter to use in my hot tub at filling time. I think its rated at like 925 gal per hour and my tub is 450 gallons. It was just shy of $100. If I start working on my tub (filling or adding) in the morning, I set the filter up that day, let it run all day and night and take it down sometime the next day and it seems to do the trick! But remember, the return line has to be above the water so there is an air gap to have the iron in the water oxidize or turn to rust to make the molecules larger and get trapped. My picture below is an older one it says the pic I took today is too large??
