Results 1 to 7 of 7
Thread: Level
    Jul 2012
    San Antonio, Texas
    6
    Level
    New pool owner and I'm putting up an intex 16x48. Question is, I'm about 2 squares unlevel on one end of the the pool, is that okay? I'm hoping it is because the pool is almost full, now. We spent all weekend getting it level and it's still off.
    30,424
    Re: Level
    I don't know how much a "square" is
    Apr 2011
    Lynchburg VA
    393
    Re: Level
    I am guessing it's a pattern on the liner?
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jul 2012
    San Antonio, Texas
    6
    Re: Level
    Yes, it's the pattern on the liner. I'm about 1 1/2 to 2 inches off.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Level
    One small section of mine is about thatmuch lower than the rest. (The one place I didn't get to put anything under the 2 posts.) If you just filled your pool in the last few days, expect it to settle a bit more before it's done. (Mine started off only about 1", then went to 1 1/2" over time.) Somewhere there are photos on here of a way to jack up the post and slide a paver or something under it. My husband wasn't willing to take the risk of breaking the posts, so mine will be slightly off until fall, when we store it for winter.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Level
    Boy this is a common Intex question.
    2" is towards the max limit of unlevel, your putting things at risk at this level or beyond. No one can tell you for sure if it will continue to become more unlevel or whether or not it will collapse. Its your call.
    Personally, I would do what it takes to correct it so as not to endanger my family.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Level
    2 squares is more unlevel than I'd be comfortable with. Especially if it's a whole "side". One square is pushing it IMO...
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
