Results 1 to 15 of 15
Thread: SWG pros/cons
    SWG pros/cons
    Replacing liner and been thinking about adding a SWG. I'm very tired of testing and adding bleach daily. Does the SWG make it easier to maintain your FC level? thanks for any information. I've been bleach for two seasons.
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: SWG pros/cons
    I have a cheap Intex SWG. I see a bit more corrosion with the salt but I will live with that because the ease of having the SWG hugely outweighs the con. I haven't added chlorine manually for a few weeks now. My SWG runs 4 hours a day, I test chlorine levels an average of every other day. SWG is painless from my experience.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    38,370
    Re: SWG pros/cons
    First, SWG are generally more about convenience than cost savings. You will still need to be testing pH and FC levels at least a few times a week.
    Pro: no hauling bleach, more consistent lower FC level, easier to go on vacation
    Con: upfront cost, possible corrosion, faster pH rise
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Re: SWG pros/cons
    I got my first pool last year and an Intex SWG at the same time. So I'm afraid I can't offer any comparison, as I have never used the daily bleach method before. Having said that, I would not want to be without my SWG. I'm not a very dilegent person, so I would also get tired of having to test and add bleach everyday. I do have to keep an eye on the pH though, as it tends to rise with an SWG, but only every few days. Plus, it just plain works. My pool is crystal clear. If you're interested in an SWG, then I'd say go for it. They do make pool maintennance much easier.
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    Re: SWG pros/cons
    I hate to sound stupid but what is an SWG?
    Richard
    38,370
    Re: SWG pros/cons
    Quote Originally Posted by abru88CJ
    Richard
    Not stupid, just new to the terminology.
    SWG = SaltWater (chlroine) Generator
    I recommend you start reading Pool School (button at upper right of the page) to learn some of the our crazy terminology
    Re: SWG pros/cons
    Sounds like it's the way to go. Are they easy to install?
    Central, VA
    Feb 2008
    Milford, CT
    333
    Re: SWG pros/cons
    Quote Originally Posted by koliver13
    Not too bad. Some more complicated than others (I think the complication of install is directly related to how many features the unit has). Basically salt needs to be added to the pool at least 24 hours ahead of time, a control panel/power supply needs to be wired into power, the cell needs to be plumbed into the pool plumbing, then the cell connected to the control panel/power supply.
    My Pool Pilot Digital install took me probably 4 hours spread over two days, but only because I had to deal with mounting it in a shed, changing up the incoming power wire, etc. If I left everything outside I probably could have finished in half the time.
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: SWG pros/cons
    Got my SWG with my pool 2 years ago. The only CON I have is that I can't use it throughout the year. I keep my hot tub running all year and go back to chlorox during the cold months. Going away for a week or weekend is fun knowing that the pool is getting plenty of chlorine. All PRO's here!!!
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Aug 2010
    Dallas, TX
    4,052
    Re: SWG pros/cons
    Simple to install, at least mine was. Doesn't get any easier.
    Why do you run your pump 24/7?
    Re: SWG pros/cons
    Yes, i do run my pump 24/7 is that important?
    Central, VA
    Feb 2008
    Milford, CT
    333
    Re: SWG pros/cons
    I think RobbieH was asking why you run the filter 24/7.
    Since a SWG is a constant source of chlorine (i.e. providing chlorine as long as its powered up and the filter is running), if you keep running 24/7 you will need a unit that can go down to almost a trickle of output to prevent overchlorination.
    Your choices are to not run the pump 24/7 or put the SWG itself on a timer so its only running part of the time while your pump runs 24/7.
    Aug 2010
    Dallas, TX
    4,052
    Re: SWG pros/cons
    But you also should not have to run your pump 24/7. You are just burning electricity!
    Re: SWG pros/cons
    Sorry miss read that. I just always have. It wouldn't bee a problem to run it part of the day. Is it best to run during the day when in use or overnight? Thanks for the input.
    Central, VA
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: SWG pros/cons
    I think it is best to run the swg during the day (when it is needed most).
    I love my swg...the only issue I have is since it is so simple and hands off, sometimes the temptation to not "need" to test is there, so one could loose track of the pool chemistry. Then even with a swg there can be problems.
