Results 1 to 14 of 14
Thread: Propane gauges?
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    Propane gauges?
    I was thinking about buying one of those propane tank gauges which tell you how much propane is left in the tank. Do they work, are they accurate?
    TY!
    Dan
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
    Re: Propane gauges?
    I've never had one that read correctly. My last one developed a crack in the lens, fogged over, rendered useless.
    I just went out a bought a full spare tank.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,651
    Re: Propane gauges?
    I have two that have worked well for years.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Propane gauges?
    The best I've found are the stick-on kind that you pour warm water on. They are dead accurate and simple.
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    Re: Propane gauges?
    Thanks all!
    John, those stick on ones, I'm guessing they only show the level while you're using the tank, because it reads the temp of the tank, right?
    Or when you pour warm water it'll show the level of a tank regardless?
    Dan
    22,553
    Re: Propane gauges?
    Your best bet is to get cylinders with float level gauges built in. They're the most accurate. I've never had any luck with those pressure type gauges. They never let you know you're getting low until you're out and then it's too late.
    Here's one place to get them.
    SW Indiana
    9,199
    Re: Propane gauges?
    Quote Originally Posted by DCAG
    Thanks all!
    Dan
    They'll show the level anytime your pour the water.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Propane gauges?
    Bama, Thanks for the info & link on where to get tanks with the float gauge. My experience with the pressure gauges mirror yours. I'm a float gauge and scale guy myself when it comes to determining how much propane is in the tank.
    BTW, for you tailgaters out there, here is a handy portable gauge calibrated specifically for standard 20 lb tanks (the most common size grill tank) http://www.northerntool.com/shop/too...2613_200372613 This is a weight-based gauge - hook it on tank's fill collar and pick it up. Will tell you how much propane is in tank based on the weight. Have used this for years and it is extremely accurate, not to mention convenient. I'm thinking about getting a spare just in case it were to ever get misplaced.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Propane gauges?
    I know this is only slightly related but I was doing some propane shopping recently and the subject of exchange propane tanks came up. I know the having my tanks filled is more cost effective but the exchanges are quick and easy... and a rip-off. When they started doing tank exchanges they were adding about 18 pounds of propane by weight. The difference is now the exchange bottles are filled to 15 pounds and are the same price or more. I have heard the tare weight of the bottle is not always taken into consideration but I doubt that.
    Do your self a favor, get two bottles and have the rental yard or gas station fill them, but confirm they do not have either a flat-rate or $20 minimum charge per bottle.
    -- Guy --
    Jan 2010
    Randleman,NC
    620
    Re: Propane gauges?
    Quote Originally Posted by techguy
    Amen,,I stopped getting the tank exchange because you don't get has much gas..Just started filling them up myself..Has far has the gauges.Had one inline for about a yr.Using grill one evening&showing out of gas&was acting like it was out of gas..So unhook'd the gauge & stiil had plenty left..Don't know what was wrong..But, they are nice to have when they work.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    Re: Propane gauges?
    That's what I used to do. A couple of seasons ago, I found a coupon to have a tank filled for $10. So we went to that place, and had the tank filled. I think that tank lasted two grilling sessions. I wasn't happy, and haven't gone back there. Now, I usually exchange my tanks at Walmart for $20.
    I still haven't bought gauge.
    Jan 2010
    Randleman,NC
    620
    Re: Propane gauges?
    Exchange at wally world&other exchange you are not getting full amount of gas than taking to somewhere&having filled on the spot..So it is costing more money
    Bucks Count PA
    73
    Re: Propane gauges?
    Local BJ's wholesale club fills propane tanks and only charges you for what you need. I have taking them half full tanks right before a party to have it topped off. I also have a spare tank for backup.
    Inground Grecian 20,000 gallons vinyl liner
    Hayward 250 BTU Propane heater
    Hayward DE Filter
    1 HP Northstar Pump
    Spill Over Spa
    Re: Propane gauges?
    I have one of the gauges on my tank. I agree it's not accurate, but I've learned to use it. Basically, I take a look at where it sits when the tank is full... once the needle starts to drop, it's time to get the spare filled up.
    I've been swapping bottles up til now. I finally found a re-fill place close enough to the house that it is just as quick to get it filled.
    10k-18k gallon Gunite pool Approximately 4-6 years old
    Blue Haven built w/ all Blue Haven equipment
    Barracuda G2 'pool boy'
