vacumming question?
Feb 15, 2011
27
Should I shut off the pump first then hook up the hose to the skimmer or can I leave the pump running?
I vacummed last week the filter gauge was going crazy back and forth from 0 to 10, is this normal.
Hook up the hose while it is running.....use the return to fill the hose.............and be quick! Those gauges are cheap. You gettin' a steady flow from the return? Pump making any unusual noise?
