Thread: Tile around pool
    Tile around pool
    Anyone know what we can use to clean it good. Give it that "new" look. I am attaching a picture so you guys can see what I am talking about..
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    May 2011
    lebanon tn
    370
    Re: Tile around pool
    muriatic acid- same stuff you use for pH down!
    Its actually sold as a concrete cleaner at Home Depot/Lowes
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Quote Originally Posted by madwil
    so just put some muriatic acid down and scrub it down?
    Bel Air, MD 21015
    I would dilute the muriatic acid with four parts water to one part acid first and then apply it with a sponge or brush, let it sit for a little bit, scrub a little and then rinse off with a garden hose. If you do try that, use googles and gloves and wear clothes you don't mind destroying.
    Tile soap will also help, and isn't as much of a pain to apply. Some people mix the soap with acid and apply both at once. It might be good to try out a small area first before tackling the entire coping.
    May 2011
    lebanon tn
    370
    guess I should have mentioned having a little caution with the acid- you definitely don't want the fumes coming directly into your eyes/sinuses!
