Thread: Paramount Water Valves
    Aug 2010
    Sarasota, FL
    22
    I noticed that my pop ups on the pool floor were all up at the same time. I suspect its the water valve module that's causing the problem.
    Any thoughts?
    20k gal pool/spa, marc, 2 hp pentair whisperflo, Pentair clean & clear filter, Raypack Reheem 266 heater. Taylor K2005 test kit.
    Aug 2010
    Sarasota, FL
    22
    Re: Paramount Water Valves
    I'm replacing my paramount 6 port module. After I removed the module I notice on the bottom it appears some type of gasket was applied. It was white in color and pretty deteriorated. Does anyone know what to use for the gasket?
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Found this on the Paramount blog...
    http://www.1paramount.com/blog/2010/04/ ... eshooting/
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
