Thread: Water Softner and alkalenity
    Jun 2010
    San Antonio
    424
    My household water has a CH of 250 and a TA of 280. Will a water softner reduce one or both of these numbers?
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    30,432
    Re: Water Softner and alkalenity
    It will essentially eliminate the CH.
    It seems to me that it would not have any affect on TA but I don't know for sure.
    Mar 2007
    San Rafael, CA USA
    12,082
    A water softener (ion exchange resin) should not change the TA.
    Jun 2010
    San Antonio
    424
    Thanks guys. I knew you would know the answer. Another question: other than cost what are the advantages and disadvantages of using potassium versus salt in a water softner?
    Larry in Texas
    Feb 2010
    Houston, TX
    271
    As far as I know, the only advantages to using potassium are:
    1. That it will eliminate the (very slight) salty taste your water may have.
    2. If your discharge line drains into your yard, over time salt accumulation may kill anything growing in that area - but usually that only happens when you're using too much salt for each regen cycle. If it drains into the sewer system, no problem.
    Our discharge comes out salty, but it's been draining into the same part of the yard for over 25 years, and the grass there is alive and well. I really think it's a matter of personal preference.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Jun 2010
    San Antonio
    424
    Thanks
    Larry in Texas
