Results 1 to 8 of 8
Thread: Having the gang over for a swim.
    Dec 2007
    Central New York
    504
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Feb 2008
    Denton, TX
    5,061
    Re: Having the gang over for a swim.
    I'd raise your FC a couple after the pool empties out. That's just what I would do though.
    Jul 2010
    North Central KY
    20
    Quite the gang you have Hotrod, I hope that you have enough hot dogs!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The thought of that just gives me the heebie jeebies.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by frustratedpoolmom
    Ditto - nothing pleasant about it BTW, FPM, Happy belated b-day... Hope you had a great day. You're one of the of this forum!
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    I think that one guy wants to get out to pee.
    But can't.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Ha! There's not even a pool in that picture. They're just walking down the street.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by Melt In The Sun
