Thread: Vac to waste?
    Aug 2009
    Bradenton, Florida
    11
    Vac to waste?
    Can someone please define what "vac to waste" consists of. Is it simply backwashing or cleaning your filter?
    8 K pool, cc 100 filter, Auto-Pilot SWG, 1 HP Whisper-Flo pump, in-ground gunite pool 9 yrs. old,solar heat and Pentair 250K heater.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Vac to waste?
    Hi!
    Quote Originally Posted by jaybo500
    Nope - it totally bypasses the filter and goes out the waste line. Backwash reverses the water flow through the filter and then out the waste line - used to clean the filter grids of accumulated dirt; "Rinse" = "filter to waste" - it runs water through the filter and out the waste lane.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Jul 2009
    Seattle, WA
    89
    Re: Vac to waste?
    It will provide a little more suction and may save you some time and clorine if you're fighting alge.
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Vac to waste?
    It also empties ALOT of water from the pool in a short period of time.
    Apr 2009
    Orange Park, FL
    104
    Re: Vac to waste?
    Quote Originally Posted by frustratedpoolmom
    I can vouch for that. Here in NE Florida we've been having a lot of rain. Sometimes as much as 3-4 inches in an hour. So I've needed to drain some of the water from the pool frequently and in these situations use filter to waste.
    15x30 IG vinyl liner pool, pool cage
    Hayward S-220T high rate sand filter and Hayward super pump w/1hp motor
    Hayward SwimPure Plus SWG
    Polaris 380 cleaner and booster pump
