Thread: Can an intex patch be used under water?
    Jun 2007
    MA
    165
    We filled the new pool and theres a leak already. the only thing I have right now is the intex patch the pool came with.
    Cheryl
    14X42 Intex Ultra Frame
    Re: Can an intex patch be used under water?
    i've got a simular problem except mines empty and we haven't even used it yet. then the dog chewed a wole in this brand new liner. intex are not the most helpful folks most of the time. good luck with yours!!
    ~David~
    Resilience SCC25 SWG, 14,585 gallons includes overflowing Jacuzzi, Rock Waterfall, Sand, IG, Pebble, Hayward Supra II 2 hp, Hayward S311SXV with 2" pipes (Sticker = GPM =99, user manual GPM = 80).
    Jun 2007
    MA
    165
    I used an under water patch seems to be ok can't really tell yet if it's still leaking.
    Cheryl
    Buy yourself a vinyl pool patch kit (available at any pool supply store, and Walmart even carries them) for under $10. You can cut the patch to the desired size and install the patch under water. As long as you smooth out the patch and remove any air underneath, the patch will do the trick.
    33000 IG vinyl pool
    Mar 2007
    Coastalish 'down easter'
    4,160
    You can take a look at this post for tips on patching a liner
    I'm here most days if you have further questions on liner patching 8)
    Good luck in getting those pools leak free so you can really get in and enjoy them
    Luv& Luk
    -Ted
