Thread: Salt water generator
    Aug 2016
    Toronto/Ontario/Canada
    1
    All of the led's on my Pentair IC40 salt generator are out. Unit is 5 years old. Has not been productive for the whole summer even though led's indicate everything is normal. But now entire unit has shut down.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,550
    Re: Salt water generator
    larry,
    Welcome to TFP..
    If none of the lights are on, then I would suspect a Power Supply failure. If the IC40 is not being powered by an automation system, then the stand-alone power supply box has a fuse in the bottom that you might want to check. If powered by automation, then there should be a small circuit breaker in the upper right corner of the main panel.
