Thread: Is there any CYA in Leslie's Fresh n Clear Non-Chlorine shock?
    Jun 2016
    Western Connecticut
    47
    Does anyone know if there is any CYA in Leslie's Fresh n Clean non chlorine shock? Thanks
    32,500 gallon in ground Gunite/White Plaster, Pentair Cartridge Filter, Pentair Propane Heater, Pentair Racer robot cleaner
    domct203's Avatar
    Jun 2015
    CT
    3,593
    Re: Is there any CYA in Leslie's Fresh n Clear Non-Chlorine shock?
    Quote Originally Posted by Clyde View Post
    I do not believe so as it is not a sanitizer and doesn't add FC, it is an oxidizer usually used to activate a bromine pool, or eliminate high CC's. It is MPS (monopersulfate) and is generally not needed in an outdoor pool.
    http://www.troublefreepool.com/threa...Clear-Question
    I do know for a fact that there is zero CYA in liquid chlorine (aka bleach).
    What is your plan for the Leslies product that cannot be addressed with liquid chlorine?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    It is probably
    MPS
    KMPS
    Potassium Monopersulfate
    Potassium Peroxymonosulfate
    A non chlorine oxidizer or 'shock'. It is acidic and will cause lower pH and TA. It adds sulfates to the water. Will not break down CC but helps prevent it from forming when used on a regular basis. It will interfere with TC and CC tests unless special reagents are used in testing since it WILL test as CC! A good choice to use in indoor pools that are not exposed to sunlight but really has no advantage in an outdoor pool. It is only an oxidizer and NOT a sanitizer and should not be used as such.
