I'm having trouble with this test as well. I had an RO service done to my water. The tech took a sample to Leslie's and the CYA read 10. Fine...who knows. I bought a bottle of liquid CYA that was supposed to add 30ppm in 10,000 gallons (my pool is a little over 14,400). I dumped it in over two applications. I waited a day and took it back to Leslie's and it read 28...reasonable based on where I started. I added a pound of dry CYA and left it over night to try to get it to dissolve (sock method). It did a bit (maybe 50%). I waited another day to test with the Taylor kit and I fill that vial up and the dot is clear as can be. The solution, after mixing, wasn't very cloudy at all. So it is saying CYA is zero. Not sure how that can be.
Am I doing something wrong here?
