Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Is it OK ? I am a new owner of pool ...
    Jul 2016
    toronto
    18
    I bought a house with a beautiful pool . After played twice last week , I begin to double about water quality. Today I get some tester ... Who can help to read ?
    Thanks a lot .
    in ground pool , spa , K2006
    38,475
    Re: Is it OK ? I am a new owner of pool ...
    Welcome to TFP!!!
    We at TFP teach people to maintain their pools based on one critical thing: accurate test results. Unfortunately, test strips like you have do not qualify as accurate and are really not much better than guessing. If you want to take control of your pool and prevent problems, I highly recommend you invest in one of the Recommended Test Kits. The K-2006 might be your only option given your location north of the border.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Trying to read test strips in person is a guess at best. Trying to read them on a pic on who knows what kind of display is a disaster. Your best interpretation is the best you can hope for. But, it isn't very good unfortunately.
    Jul 2016
    toronto
    18
    Ok, just purchased K2006 ... Will arrive next week ...
    Stop swimming now on ...
    Any other thing to do ? Thx .
    从我的 iPhone 发送,使用 Tapatalk
    DFW, TX
    24,512
    It is safe to swim when
    FC is above minimum for your CYA so the pool is sanitary
    FC is below shock level for your CYA, FC/CYA Chart
    PH Is between 7.2 and 7.8
    Water is clear
    Jul 2016
    toronto
    18
    k2006 arrived
    Jul 2016
    toronto
    18
    Jul 2016
    toronto
    18
    I should start by this ?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Do each test in order. FC, CC, then pH, TA, CH, and then CYA
    Post the results and we can go from there.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    885
    Hey nice kit- the general order to perform the tests is
    FC
    CC
    pH
    TA
    CH
    CYA- should be performed on a sunny day, back to the sun at waist height
    It is the same order on the test instructions. Post your results for us to look at if you like.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jul 2016
    toronto
    18
    Thanks, here is first step result .
    Jul 2016
    toronto
    18
    When I completed first test , the water turned to colorless. And after minutes , it turned to pink again!? Is it correct ?
    Jezza's Avatar
    Jan 2015
    885
    Did you add the powder and it turned clear straight up (before adding R-0871)?
    K-2006
    Jul 2016
    toronto
    18
    Quote Originally Posted by Jezza View Post
    I am sure for that .
    Jul 2016
    toronto
    18
    Test 2: PH7.8
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by bestman View Post
    It is normal, it does that- all it counts is the immediate color change. You're quite low on chlorine and your CC is high- what are pH & CYA numbers?
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jezza's Avatar
    Jan 2015
    885
    That would then mean no FC or chlorine in the pool -can you post up your full test results?
    K-2006
    Jul 2016
    toronto
    18
    Test 3: Total Alkalinity 110PPM
    Jul 2016
    toronto
    18
    Test 4: Calcium Hardness Test:390ppm
  20. Back To Top    #20
    Jul 2016
    toronto
    18
    Test 5 : Cyanuric Acid Test: 35or9?
