Hi Everybody!
I bought a house last month that's got an awesome pool in the backyard. Gunite pool+spa, about 18000 gallons best as I can approximate, liquid chlorine setup. I'm fully intending to DIY as much as possible. Done a ton of research through Pool School, r/pools, and these Forums! Super happy to be here and part of your community.
On to business...
Water temperatures today was 55F in the pool at 60F in the Spa. Here are the measurements I took with my new TF-Pro test kit.
PH: 7.7
Cl: Off the scale (orange)
FC: 21ppm (43 drops of R0871 counted)
CC: 0
TC: 21ppm
CYA: > 100
CH: 500 (20 drops)
TA: 120 (12 drops)
Pool is not yet open, planning to wait another week or two until things warm up just a hair. That said, I'm trying to develop a strategy for when when I do eventually fire things up.... My CYA is clearly off the charts (attached pic of view cylinder from TF-Pro). I'm guessing it's ~130-150. I guess it makes sense CL is so high... Based on what I know about prior owner, I think they just continuously added Chlorine product with stabilizer included from the pool store over the years, never bothered actually checking stabilizer levels. Water is pretty clear under the cover.
I am hoping to fully embrace TFP methodology, so clearly need to get my CYA down. I've got a few questions I'm hoping ya'll can help with my planning:
On to business...
PH: 7.7
CC: 0
TC: 21ppm
CYA: > 100
CH: 500 (20 drops)
TA: 120 (12 drops)
- If I'm doing water replacement to get CYA down, is it reasonable to shoot for a target of 60 per TFP recommendation for Liquid Chlorine setup? Or since I'm replacing anyway, should I just target 40? The difference is 50% to 70% water replacement in my setup... I'm feeling guilty about tossing an additional 3600 gallons if it's not absolutely necessary.
- What's the best order of operations here? My plan is to open the pool, double check measurements with pump/filter going, and then immediately start replacing water. Is there any reason to do things differently (i.e. raise FC, fully vac/clear up water, then to get replacement going)?
- Plaster seems to be in good condition with a small amount of cracking. A buddy told me that replacing that much water will totally crumble/destroy my plaster, especially in the desert where I'm at with dry air. Is this true? Should I have any concerns or take any special precautions when replacing 50-70% of my water? Previous owner told me she has never drained/refilled or done a significant replacement in 20 years pool has existed.
