Thread: Homemade scupper ideas
    Feb 2016
    Atlanta, GA
    145
    Does anyone have and budget or diy skupper ideas?
    I found these underwater rated thru-hull (boat) fittings for $12 a piece. They might create a nice effect mounted on a stone.
    Jul 2015
    Central Valley CA
    1,107
    Re: Budget scupper options
    Could work but I would avoid metal if you can unless they are specifically for pools that way you don't have to worry about corrosion or what they might leach into the water.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Feb 2016
    Atlanta, GA
    145
    Found a guy selling homemade plastic scuppers for $55 a piece.
