Thread: Leaving pool for four days
    Jun 2015
    Ottawa/Ontario
    339
    Pump and SWG will be running. Question is - do I leave the solar cover on or off?
    Thanks for your perspectives!
    Tom
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Leaving pool for four days
    IMO I would leave it off. It's beneficial for the sun (UV) to hit the pool.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    If you leave the cover on it will reduce evaporation, you will have less PH rise if your PH tends to rise and your FC consumption will be lower. If you leave it on the CCs will build up and the water will get hot.
