Thread: Koi Pond question.
    May 2016
    Pittsburgh/PA
    52
    Koi Pond question.
    How do you clear Algae out of a Koi Pond? I used a sludge destroyer and water is a ton clearer but not clear and algae is present. I can't use bleach I assume cuz of the fish.
    Any ideas thoughts?
    27' Above Ground Pool.
    Vinyl Liner
    Cartridge Filter
    TAYLOR TECHNOLOGIES INC K-2006 TEST KIT COMP CHLORINE FAS-DPD
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Koi Pond question.
    You are correct that you cannot use bleach because it will kill the koi. Here is a good koi forum where you can probably find more answers. Koiphen.com
    May 2016
    Pittsburgh/PA
    52
    Thanks.
    Vinyl Liner
    Cartridge Filter
