I did a good job with the info here for a few years...then....
I slacked and was just buying packets of treatment (couldn't get bleach during Covid for instance) and eventually wasn't testing much or at all and just dumping in stuff and sweeping...oops. I'm BACK
So it went bad end of season last year.
Became a bit of a frog pond with dragonfly babies and tadpoles swimming around.
I cleaned out a lot of solids...leaves, pollen (pear trees!) lots of sludge.
I added a bunch of dry chlorine and the water went light but super cloudy.
Kept sweeping/baskets/backwashing.
Then I added Salt. My SWG is old and probably not working but I also wanted to get rid of the frogs
More sweeping
Then added Borax. Then a little more chlorine.
CH Level was normal as was TA but I'll be checking again soon
WHICH IS MY QUESTION
CYA was extremely low unless my Test Kit is 'exoired'.
Filling up the tube all the way (to make the black dot vanish) didn't do it so it is much lower than 15.
I added CYA today plus more fresh water.
There is still too much solid stuff in the pool that I can't see for me to vacuum so I am blindly using a skimmer net and sweeping and skimming the top (though that is staying clear now).
Still LOTS of cloudy sludge in the pool.
I just backwashed, added a good bit of Chlorine packs and swept it again.
SO TOMOROW....
I'll be testing everything again in the morning.
I won't rush to add any more CYA until things balance out a bit more.
My instinct is to get as much of the solids out before wasting more chlorine.
Is there a 'ratio' for this?
I am hoping the water clears up more now that I have done two shocks and added CYA.
More sweeping
SO TOMOROW....
