Thread: Need help VS pump settings and programming IAquaLink
    Dec 2014
    Cypress, Texas
    200
    Where can I find the best way to set up my VS pump to run (run times, speed etc)?
    Also since I have the IAquaLink controller where can I get easy to follow instructions on how to make those settings?
    2016 Build: 32x8 Gunite, 6,700 gallon IG pool including 6x8 spa and 6x8 tanning ledge w/ 2 bubblers. 32' raised wall with two sheer descent water features. Travertine Coping w/ split faced Travertine on raised wall face. 2HP VS Jandy pump, 400k heater, Rainbow Chlorinator, 4 Colored LED Lights. 459sqft spray deck plus. IAqualink remote, Polarus 9350 Robot Cleaner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Need help VS pump settings and programming IAquaLink
    Can't help with the automation.
    The best place to start is with 2-3 hours in the morning and 2-3 hours in the evening. Start at a low speed and short time and work your way up as needed.
    I run my pump at 1100 rpm (150w) for skimming, filtering and making chlorine with the SWG. Works great!
    Dec 2014
    Cypress, Texas
    200
    Anyone have experience programming run times and speed on IAquaLink website? I'm having trouble figuring out how to do multiple run times and pump speeds.
    My PB has it set up to run on full power from 9-11 am and then on low (don't know how to tell the speed) from 11- midnight.
