I have what I hope is an easy question re programming my iAqualink 3.0.
I have a Jandy VSP ePump, 600-3450 rpm. Filtration schedule set to run at 2000 most of the day with two periods of 2800 rpm to help with skimming. All of this works fine.
We have "water features" (spa overflow, scupper) powered off the same pump. When we're enjoying the pool, we like to have the water features turned up for aesthetic purposes. I set up a One Touch scene which, when activated, increases the pump speed to full 3450.
For some reason, when I turn the "water feature" scene off, the pump doesn’t return to filtration mode but simply turns off. I have to manually turn the filter pump back on, and if I forget, there’s no water filtration until I notice the water isn’t circulating and manually turn it back on.
FWIW, when I turn on the "water feature" setting, both the "water feature" one-touch icon and the filter pump icon are lit. When I turn off the water feature setting, the filter pump icon turns off as well.
Behavior is the same whether I manually turn off the water feature or have a timer turn it off automatically.
Is there any way to have the system return to filtration mode when the one-touch scene is turned off?
Thanks.
Thanks.
