Results 1 to 18 of 18
Thread: Need new brush
    May 2016
    Freehold
    27
    Need new brush
    Seems every nylon brush I have falls apart and the nylon ends up in the pool....
    What is the best type of pool brush that won't fall apart?
    (I did see some older posts but nothing newly posted on pool brushes)
    THANKS!!!
    Freehold, NJ 22x44 36k gal gunite , SALT system Nature 2 Fusion Soft (NO mineral cartridge), Jandy LXi gas heater, Jandy DEV60 DE filter, 2HP pump, Jandy LED lights (GARBAGE little use in 3 years BROKEN), Polaris 280 pool vac, Meyco mesh (too windy for solid), separate hot tub--Grandee Vista by Hot Springs w/ ACE salt system! Wish I never bought a pool most days but some days, I do finally relax! I do appreciate the help! K2006 & strips
    38,547
    Re: Need new brush
    You can get a mixed stainless/nylon brush ... but eventually the nylon is always going to fall out.
    I recommend the Wall Whale (not the XL) which is all nylon.
    Aug 2014
    Northern IL
    4,615
    Re: Need new brush
    I have a wall whale too and love it for the walls. For the floors and steps, I just bought a new one at the pool store that supposedly has UV protection in the bristles. So far so good.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: Need new brush
    The wall whale has lasted a couple of years, but the generic nylon brushes usually only lasts me one season. My stainless steel algae brush has lasted many years.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    May 2016
    Freehold
    27
    Re: Need new brush
    thanks. I don't have a stainless steel brush at all. Can you even use one on gunite? what is benefit of stainless steel over nylon?
    Anyone know best deal for the whale wall brush?
    38,547
    Re: Need new brush
    Stainless just is firmer. I would not use one often of plaster unless the plaster was old.
    Inyopools will price match if you find a better deal, just mention TFP.
    May 2016
    Freehold
    27
    Re: Need new brush
    thanks, inyopools doesn't show that they sell it.... I looked under pool brushes and searched whale wall.
    38,547
    Re: Need new brush
    I did not realize it wasn't on their site. Sorry about that
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Need new brush
    Plaster/concrete and similar I'd go with stainless steel last and last. Check amazon. Have seen good rates there. It's where I got mine. If you ever get black algae you'll need stainless steel.
    Good luck.
    May 2016
    Freehold
    27
    Re: Need new brush
    Nobody seems to have this in stock even amazon says 1-2 months. I'm guessing I should get the 50/50 which is $70 and sounds expensive for a brush head.....
    manufacturer site has them but s&h is price and it will end up $65....
    Apr 2011
    Murrieta, CA
    2,360
    Re: Need new brush
    Amazon pool master 20183. $20
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: Need new brush
    I'm surprised Amazon is saying 1-2 months. It must be on back order.
    I found the wall whale here: The Wall Whale Swimming Pool Brush: Order Online
    They have a local retailer finder here: The Wall Whale Swimming Pool Brush: Find the Wall Whale in Swimming Pool Stores Across the USA
    Karen
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: Need new brush
    Karen
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Need new brush
    I have this brush and it is great, not too big of a tail for too much resistance.
    Paradise 18 Turbo Brush Swimming Pool Brush | PTB100
    May 2016
    Freehold
    27
    Re: Need new brush
    i sucked it up and paid $50 from the manufacturer site at 3am when I couldn't sleep... thanks though. Hope if gets here soon..
    May 2016
    Freehold
    27
    Re: Need new brush
    Had this whale wall a few weeks, love it but it's only been used a few times and I'm finding the nylon bristles are coming out after each use like 4-5 bristles every time, maybe more if they are falling out in pool....
    anyone else have this issue?
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: Need new brush
    I would contact the manufacturer. This is my second year on my current wall whale and it hasn't started to fall apart yet.
    Karen
    1955House's Avatar
    May 2016
    Burlington, MA
    16
    Re: Need new brush
    I purchased a SweepEase at the end of last year. It seems to work well.
    20,000 Gallon Gunite Saltwater Inground Pool
    Hayward Super II Pump (model # SP3007X10AZ) | Hayward 48 Sq. Ft. Pro-Grid D.E. Filter (model # DE4820) | Hayward AquaRite SWG (model # AQR15) | Hayward 400,000 BTU Natural Gas Heater (model # H400FDN) | Polaris PB4-60 Vacuum Booster Pump (model # PB4-60) | Polaris P39 Pressure Pool Cleaner (model # P39) | Hayward Vari-Flo Valve (model # SP715XR50)
