- Oct 25, 2015
- 5,200
- Plaster
- CircuPool RJ-60 Plus
tcrote,
It happens all the time even on jobs that are pretty well defined and straight-forward like yours, where the scope is "replace system". As you pointed out there are lots of good reasons this can happen. Unfortunately there are also some cases where the contractor left out a major part of job in his estimate, sometimes intentionally. Yes, if this is the case he still has to do the work... contractually anyway. But it will be like pulling teeth and everything will be done the absolute cheapest way possible to reduce his loss. Or he will notify you of the omission after the "hole is dug". In the end the job result is usually far inferior. That's why even for straight-forward projects I like to write out the work items. For your example it might be:
Remove and dispose old unit.
Install "brand X", "Model Y". Contractor may offer alternate with SEER rating of "Z" and describe benefit to Owner (usually price but could be performance/warranty etc). Owner's sole discretion to make the choice.
Contractor includes cost of permits, lifting equipment and delivery of materials.
Contractor has inspected system and found no additional work required.
Chris
Chris
