Thread: Plumpbing Stenner Fitting
    Mar 2013
    CT
    349
    Whats the best way to plumb the stenner fitting in an existing piece of pvc pipe? Can i drill a hole in the pvc and tap it or is there a better way to do it?
    Thanks!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Jul 2015
    Central Valley CA
    1,107
    Re: Plumpbing Stenner Fitting
    Many if not most tap the PVC and use some teflon tape. Elbows are a prefered location because the wall is a bit thicker.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mar 2013
    CT
    349
    Does the hole need to be tapped for threads?
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Mar 2013
    CT
    349
    Perfect. Thank you!!
