Thread: how long does liquid chlorine retain full potency in the bottle?
    Dec 2015
    arlington, tx
    100
    and how long will it retain full potency when a bunch is dumped into a tank using a Stenner pump?
    Jul 2015
    Central Valley CA
    1,107
    Re: how long does liquid chlorine retain full potency in the bottle?
    Assuming no sunlight is getting to it, it depends on the average temperature. Take a look at the post form Chem Geek on page 2 of this post http://www.troublefreepool.com/threa...l=1#post725315
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Dec 2015
    arlington, tx
    100
    are these numbers assuming sunlight exposure?
    Jul 2015
    Central Valley CA
    1,107
    I don't believe so, I think they are temperature only.
    You want a dark tank out of the sun so there is no light exposure and reduced heat. If possible in an air conditioned room, I don't have that option. I don't have my system set up right now because I am using almost no chlorine, when I do have it set up I have a 5 Gal bucket that sits in an insulated redwood box I only add at most a couple of gallons at a time and only buy 2 to 4 gallons at a time to keep things as fresh as I can. I have not used the system at peak summer temps since the pool is new but I think most of the time I should get more than a week out of 2 gallons and I plan on topping off every Saturday. If we were to go on an extended vacation I would of course add more and probably aim for the high end of my FC range if not a bit over just to be safe, may be a waist of chlorine but I figure it's good insurance.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No, those numbers do not take in sunlight. If you aren't shielded from it, there will be significant degradation in short order.
    Essential Links:
