- Jun 1, 2018
- 13,747
- Vinyl
- Hayward Aqua Rite (T-15)
@ChandlerInFBGTX
You likely have one of two things going on - either you have an organics problem that you just can’t quite see yet
or
- your cya is very low so the chlorine you are adding has no protection from the sun.
Cya is sunscreen for chlorine - you need some but you don’t want too much.
** Note that problem #2 can in turn lead to problem #1 due to fc falling too low.
Keep feeding the pool the 5ppm/ per day until your kit comes & you can find out what’s what. This is keeping your pool from turning into a green monster
When it comes,
You can do an Overnight Chlorine Loss Test to rule out algae being the culprit before increasing cya. The pool looks good but looks can be deceiving.
We’ll help you sort things out but we simply gotta have accurate data to do so.
Fwiw- The tfpro is very nice & in my opinion the best all inclusive residential pool kit one can buy - you’ll be happy with it no doubt.
We look forward to seeing your first results
or
When it comes,
