Thread: Help locating waste line
    Aug 2015
    Lubbock, TX
    15
    I have a pretty good understanding on the equipment outside of where my dadgum waste line is. HELP
    16,000 - IG - Vinyl (LShape)
    Sand (Purex triton tagelus ta-50)
    A.O. Smith Centurior Switchless
    Built in 1990 - everything still original
    TF-100 test kit
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Help locating waste line
    well it should be one of the two going out of the filter that is not the one coming from the pump.
    What model multiport valve is that? google for a schematic of it and it will say which of those lines is waste.
    Dolphin E10 Cleaning Robot.
    Aug 2015
    Lubbock, TX
    15
    That makes sense. Next question, it's the right line in the 3rd picture. It has that cap but also goes back into the ground. Do I need to locate where it goes under ground or can I remove that cap to help drain my pool for closing
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Looks like it is capped for winterization or another reason and that you can join it up with an extended waste line that goes back underground, possibly into a sewer connection. That splice in there would allow you to either hook up a hose at the cap and backwash where you wanted to direct the water or connect to the other pipe to the right that goes... somewhere else. Into a sewer connection is my best guess.
    Isolated Spa - 345 Gallons
    Aug 2015
    Lubbock, TX
    15
    Interesting, thank you so much. I think the safe play is to open that cap and run a hose. No idea where it goes back in ground.
    The other pipe to the far right is dead and needs to be removed completely. It was hooked up to a spa that's no longer here.
