Thread: More Reliable - Rubber Plugs or Threaded Return Plugs?
    Jul 2015
    Bergen County, NJ
    113
    Which is more reliable for return lines and skimmer lines? Rubber Plugs or Threaded Return plugs with o-rings?
    53K Gallon Plaster in-ground with ALL Hayward equipment including Omnilogic Automation, Phantom Turbo Cleaner, SwimClear Cartridge Filter, Heater, Dual T-15 Salt cells. TF-100 Test Kit w/Speedstir.
    Apr 2015
    South Central PA
    298
    Re: More Reliable - Rubber Plugs or Threaded Return Plugs?
    I think you need one or the other....a threaded one won't work in an unthreaded port (obviously) and I don't think a rubber one will seal on threads of a threaded hole....
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    The threaded caps, at least for me had small air leaks around the return jets. I did not put any Teflon tape around them and they were leaking very small air bubbles. After discussing this with the company where they were purchased, it appears that the threaded ones are designed for above ground pools. The threaded ones work great in the skimmers as the basket is flush, not like the return housing. You may have better luck. Some other members have felt the same way about the threaded ones that they leaked.
    I like the black rubber plugs as they create a nice tight seal. They tuck in nicely and stick out about 1/8". I also use the black ones for the pump basket - Both Suction and Return side as extra insurance. If the Jandy Valve from the main seal were to leak a little air, this could cause problems. The black plugs are added insurance.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I use the threaded plugs in my returns as I don't really care much if they leak because I drain below the returns. I use the rubber expandable plugs in my skimmers because I don't want them to leak. Both the fittings are internal threads and the rubber plugs seal MUCH better and easier than the threaded plugs with o-rings. The threaded plugs might work OK in my skimmer fittings because the skimmer is sound (has no cracking) but most of my returns have cracks in the flange that covers the liner so even if the o-rings seal well, there is still a crack below the o-ring to allow air or water in and out. So if I were to not drain below the returns, I'd use rubber expandable plugs.
    Isolated Spa - 345 Gallons
    Jul 2015
    Bergen County, NJ
    113
    Thanks for all the feedback. I plan to use the threaded plugs in the Spa. I will be draining the spa completely so the threaded plugs should never see any water. On the pool side, I'm going to play it safe and use the rubber expandable plugs in the skimmer and return lines. Even though I plan on draining below the returns, I have a porous safety winter cover and we get enough rain and snow around here for the water level to go back above the returns, so I'm not comfortable risking a frozen line.
