First time at trying to close my pool myself. I just purchased a Cyclone. I plan to airlock the main drain and plug the return lines after blowing them out. My question is what to plug them with. I see two types of plugs among my pool paraphernalia (see photo). One is rubber with a wing nut, the other threaded plastic with an O-ring. Are these plugs basically equivalent and interchangeable (assuming the port I'm closing has the same threading as the plastic plug)?
I gather one silicone lubes the plastic plug if it is used. Is that correct? Is any prep needed for the rubber plug?
I haven't figured out what I am doing with the skimmers yet. I will either get gizzmos for the two skimmers or plug them and put capped empty plastic bottles in them. I have a mesh cover and although I plan to lower below the skimmers, the skimmers are likely to get water in them prior to next year's opening, so I should protect them from freezing water. If I do plug them, what would the forum suggest I use?
Feedback much appreciated.
