Thread: chloor 0,0
    Aug 2015
    Arnhem/Netherlands
    109
    chloor 0,0
    I put everyday 36/40ml liqued chlorine 12,5% and sometimes my chloor is stil 0 the next day without soak.
    Can i put more about 50ML a day or is that not smart to do.
    Yes i have a ozonator.(maybey a strong one) hi hi.
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: chloor 0,0
    Yes, add more. Try to add enough so that FC is at least 1 or 2 the next day. Here is the process I use to maintain my tub and it works great.
    How do I use Chlorine in my Spa (or pool)?
    Aug 2015
    Arnhem/Netherlands
    109
    Re: chloor 0,0
    Ok Thanks i put in 50 ml.
    Factory is Caldera
    Above ground
    6 months old now.
