okay to be clear I should add the recommended amount of water. I also plan on substituting bond agent for water in the first batch that will be poured on directly to the existing gunite.
I think I understand now, watched a short video. Mix it to thick milk shake consistency and then add the packet.
The form is done. Finding the right material was the most "difficult'.I will post a few pictures later.
I am not worried about smooth finish since pebble tec will be on top, but because I am who I am I am going to do this anyway...why not lol.
1) You should really try to do the pour in as few pours as possible Doesn't look like much volume, so depending on the volume of your mixer maybe you could get it with a single batch.
2) Why are you replacing all the water with bonding adhesive? That may not be a great idea in conjunction with using a plasticizer, as the bonding adhesive has some plasticizing properties of it's own. It's also generally not recommended to replace all of the water with a bonding adhesive, most of them specify a maximum adhesive to water ratio, often 1:1 or 1:2. Adding bonding adhesive to the mix will only aid the adhesion slightly, and the other benefits like decreased shrinkage cracking and increased water resistance aren't really something you need to worry about for this application. Painting on the bonding adhesive on either by itself or in a slurry with a little portland before the pour will help a lot more with bonding than adding it in your mix.
3) In general you want the end product to be somewhat of a milkshake consistency, and the packet of plasticizer will change the consistency to be much thinner. I'd mix to a thicker consistency so that it's milkshake consistency after the plasticizer is added. Better yet, carefully measure all your weights instead of trying to eyeball the consistency, especially if you don't mix concrete/mortar on a regular basis.
4) As Brian mentioned, the rougher the better. You want some texture for the plaster/pebble to be able to grip on to.
