Yellow pH sample slowly turns purple
QPSUtah
In The Industry
Sep 12, 2024
119
Salt Lake City
Chlorine is 8 ppm
TA is 30
Base Demand requires 9 drops to raise pH to 7.4.
Is it normal for a yellow pH test (less than 7) to slowly turn purple?
I’m not sure how the pH got so low. Perhaps incorrectly calibrated pH probe.
Typically due to chlorine interference.
High CYA slows the process.
Most likely the CYA is well over 100.
Can you post a full set of readings including CC?
Was FC tested with FAS-DPD?
Post current readings and also prior readings.
Post all chemicals added since prior readings.
Is the pool on Trichlor or liquid chlorine or salt etc?
Most likely, the "Adjusted" or Carbonate TA is zero.
What is the CYA?
Borates and Adjusted Alkalinity​
Adjusted TA = TA – (CYA X CYA C.F) – (Borate x Borate CF)
Borate C.F (correction factor) based on pH.
pH.......CF
7.2.....0.051
7.4.......0.0786
7.6......0.1248
7.8......0.1989
Cyanuric Acid correction factor based on pH.
pH........CF
7.0.......0.22
7.1.......0.24
7.2.......0.26
7.3.......0.28
7.4.......0.30
7.5.......0.32
7.6.......0.33
7.7.......0.34
7.8.......0.35
7.9.......0.36
For example, if the pH = 7.6, TA = 90, Borate = 50 and CYA = 70, the adjusted alkalinity is 90 - (70 x 0.33) – (50 x 0.1248) = 60.66.
Reactions: Mdragger88
Phenol red gets converted into Chlorophenol red with high FC.
Chlorophenol red is a pH indicator dye that changes color from yellow to violet within the pH range of 4.8 to 6.7.
The pH is likely to be about 6.4.
Did you ever get a pH meter?
It’s a commercial pool. Uses liquid chlorine. Just opened for the season. Chlorine feeder is off due to ruptured tubing, so added two gallons manually to raise chlorine.
At the time I took the readings yesterday, the acid feeder had been running and reading 7.2, so was not properly calibrated and had fed too much acid in.
It’s just odd to see the color change like that.
Reactions: JamesW
Reactions: JamesW
Free chlorine was 8 and CYA was 0 (semi public pool (apartment) with liquid chlorine system).
I ended up dosing with Soda Ash to raise the pH and it's now doing fine, but just weird that I was seeing it change like that. Maybe 8FC was enough to do that.
0 CYA makes the process happen pretty fast, so maybe more noticeable.
If you had CYA, the process is slow enough that you have already taken the reading and dumped the sample before the reading changes enough to be noticeable.
Normally, the problem is caused by trichlor use, which is why I was thinking high CYA.
An overactive acid feeder is a less common cause of readings like this.
Definitely need better maintenance, training and oversight on the automatic feeders.
There have been some serious accidents caused by feeders going berserk and dumping acid and/or chlorine into a commercial pool causing many injuries.
Is 8 ppm acceptable for that commercial pool?
8 ppm with 0 CYA is pretty harsh on bathers.
Is the liquid chlorine feeder also automated?
Is it on ORP control?
What was the ORP setting and reading?
Is that feeder also overfeeding?
