- Jul 18, 2012
- 144
duraleigh said:I would add enough granular stabilizer to get to 30-40 ppm. Then use your pucks if you want to until you get to 50 ppm and then stop using the pucks and you'll be just right. That's using good testing to manage your pool water.
You could also save the pucks for when you are away and can't add bleach. Simply manage your CYA and chlorine carefully and you won't have any problems
Awesome! I bought a 4 pound container of stabilizer (HTH brand from walmart) and will add some tonight. I can't remember the dosage but I think it was 2 pounds to raise it 10ppm for 10K gallons. Think I will start with the 4 pounds which should add 10+ to my pool and test it again in a week or so. Then take it from there.
I can't seem to find it....and I have searched.....on average, how many gallons of bleach does it take in a month to maintain chlorine levels assuming water is balanced? I ran some pool calulator stuff where I put in my current FC readsing of 1 and used 4 as my goal and it said I needed about 115 ounces or so for my pool to get it there.
I guess I am missing the part where it says...how long will it stay there. I assume I am not adding 115 ounces a day. Is it always different depending on the pool? I know I need to test everyday and I can use the calculator to help me but didn;t know if there is an "average" monthly use that someone could share.
Thanks
