- Mar 3, 2022
- 2
- Plaster
- Jandy Truclear / Ei
I am working on getting my pool into shape after having a pool company taking care of it. A perfect example for "if you want it done right, do it yourself". which seems to be the motto here.
I have a Jandy Tru Clear SWG, their spec sheet says CYA should be 30-50, TFP CYA/FC chart says 70-80. Are there any potential problems increasing the CYA above Jandy's recommended levels?
I also have a tendency to have high chlorine levels. I think part of that problem is that when I checked the salt level it was at almost 4200 and Jandy recommends 3300 with high of 3500 and low of 2700. So it is probably breaking out more chlorine due to the high salt level. I would have to empty out about 3000 gallons, which I really don't want to do, (occasional heavy rains displace some of the water, but less this time of year than in the summer)so I have reduced my generator to 20%. I have never change the timer on the pump from what the builder set it on and it is currently running 12 hrs.day, which seems to be a turnover rate of about 3.3 times per day for the 9600 gal. pool. Should I reduce that before cutting back on the generation %?
And my third area of concern is my pH level. To keep the pH in range I need to add 1-2 cups of acid daily. Yesterday I dropped the pH to between 7 and 7.2 and ran my water fall to aerate the water some and today my TA was 80 (down from 90) and my pH 7.6. Any thoughts on stabilizing the pH or is this just something to live with using a SWG.
I am using a Taylor K-2600 C test kit for chemicals and eSeasonGear SALT-3050 Salt Meter
Any and all help appreciated
