- Jul 18, 2017
- 244
- Plaster
- CircuPool RJ-30 Plus
I need some guidance.
My scenario: I currently have an old single speed pump running on a 15amp 220v circuit connected to an Intermatic mechanical timer. I want to upgrade my whole system to Circupool equipment (vsp pump, filter, swcg).
My original idea was to hardwire the pump and connect the swcg to the timer. That sounded easy enough, but considering I only have one electrical source out there at the pad, I'm not sure how to do that, or if I can, or if I should. Can the pump be pigtailed to bypass the timer? And is 15 amps even enough?
Considering my situation...how would you go about doing this?
Our pump is totally on it's last leg right now so I was about to pull the trigger and just order everything all at once, but I'm thinking for now I might just have to order the pump by itself and do the rest later.
I'm willing to call in an electrician if I need to upgrade the breaker or something, as long as I don't end up having to rewire my entire house.
Your advice is greatly appreciated...I've went round and round with this and I've only succeeded in confusing myself more than I already was.
Thanks!
Thanks!
